sy84
205 Gti6 Charging Problem
sy84
hi iv got a 205 gti with a gti6 engine convertion
i have only just brought the car yesterday and its got a charging problem,its got a new alternator but still its not charging the battery,i have put a multi meter onto the teminal on the alternator and its got power there,also the battery light on the dash is on permanantly....even with no key in the ignition.
any one got any idears what could be wrong?
Paul_13
Have you connected the smaller wire to the 8mm hex nut terminal on the alternator?
Who was the wiring carried out by?
Has the small wire been connected to the car side of the loom?
sy84
the new alternator was already fitted my the guy i brought it off,i dnt have a clue who did the wireing.n yea the small wire is on the smallest terminal on alternator.also the spade conector on bottom end of alternator is wired direct to battery is this rite?
Paul_13
Err the last bit don't sound right. There should only be 2 wires going to the alternator, one to the 13mm nut and one to 8mm nut.
Is it a 205 or 306 alternator?
Post a pic if your not sure and we can help.
Something does sound amiss though with that cable with the spade terminal.
sy84
id say its a 306 alternator,i can't get to the car atmo to take pic
Paul_13
If it's a 306 alternator it won't have a spade terminal going to it.
What did the volt meter read when you measure the volts coming out the alternator? Should be 14.4v when charging.
sy84
ummmm i dnt no then.its got two bolt on terminals towards the top of alternator and spade 1 towards under side,i didnt have engine running when put volt meter direct to aternator coz i removed the inlet manifold to gain better acsses to the wireing,when it was running i just tested the volt reading across battery both with engine off and running
Paul_13
Ok, rules out starting it then.
Post a pic mate and we can start picking faults :lol:
sy84
ok m8 i can't get to car to uploads pic atmo will go up to where im keeping it tomoz then upload sum pics,thanks for your help :)
Paul_13
This is all that should be on the alternator :)
sy84
yea looks like that on top but with the extra conection dwn the side of alternator
sy84
My link
the second diagram here shows 3 conections goin to alternator like mine
sy84
i took the pug too a auto electrition he took the spade conector wire out n told me the rest of alternator is wired up rite but its my alternator thats falty so today i replaced the alternator but still no charge,any one know what else i sould try?
