erbs 42 1 Cars Posted November 11, 2011 (edited) been looking at mounts and found that gsf have them,are they any good? or would it be worth going to main dealer? this for road use only Edited November 11, 2011 by erbs Share this post Link to post Share on other sites
welshpug 1,737 Posted November 11, 2011 They'll be ok for a base model, but fro a normal road going gti it's best to use o.e, they don't cost that much. ask for one for a diesel, the oddities of Peugeot's servicebox means the bush on its own is not listed for the gti but the same bush is listed for the diesel and is shown on the system Share this post Link to post Share on other sites
erbs 42 1 Cars Posted November 12, 2011 (edited) my local dealer has got one 24 quid is that about right? bottom rear bush needs replacing Edited November 12, 2011 by erbs Share this post Link to post Share on other sites
Phil H 16 Posted November 12, 2011 My GSF one one was perfect. No issues at all. Local factor sells them for £10. Share this post Link to post Share on other sites
welshpug 1,737 Posted November 13, 2011 £24 sounds about right, cheaper than £80 odd for the comlete mount! Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted November 13, 2011 I've got a 309 DT bottom mount I am going to be using. Find BBM grp N one too stiff. This is with a gti6 engine BTW Share this post Link to post Share on other sites
erbs 42 1 Cars Posted November 14, 2011 (edited) OK got the bush from Peugeot, think I'm gonna try and do it without taking it all to bits and here is my plan get old bush out ,clean mount as necessary, get new bush and stick in the freezer for a couple of hours and once nice and cold heat up mount with blow torch and hopefully will go in easier than bashing it in i always do this with bearings as they just drop in the hub without the need for pressing in Edited November 14, 2011 by erbs Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 14, 2011 Good luck, these need a decent press in usually. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted November 17, 2011 well just an update What i done as described earlier froze bush in freezer for a few hours then when ready heated up the mount so it was scorching hot greased the bush and got my club hammer and offered up the bush, a few whacks and slid straight in, and thought to myself that was easy?? took longer to get the old bush out and about 15 seconds to put new one in, the good old heat n freeze works wonders Share this post Link to post Share on other sites
welshpug 1,737 Posted November 17, 2011 what did you use to heat the mounting up? Share this post Link to post Share on other sites
erbs 42 1 Cars Posted November 17, 2011 I'm gas engineer so I used my trusty mapp gas blowtorch Share this post Link to post Share on other sites
erbs 42 1 Cars Posted November 17, 2011 Oh and I used a 70mm diameter bit of steel pole about 100mm in length, it's the same size as the bush Share this post Link to post Share on other sites
welshpug 1,737 Posted November 17, 2011 I see, I wonder if gas mark 8 for a bit will do the trick... Share this post Link to post Share on other sites
