erbs
Rear Beam Removal
erbs
what is the difficulty rating for this?? are the bolts likely to be buggers to get off?
just going thru the inspection stage seeing whats what
omega
if you check the main site theres a how to guide on there that might help you.
Quite easy, all the main beam fixing bolts to the shell will come undone.
Only thing likely to cause most bother are brake hoses.
allye
Don't do it by yourself! Sh***er of a job if you do. easy job other wise just big and bulky. Bolts should be fine as they are inside.
marksorrento205
If your just unbolting the beam complete, then its a doddle. The 6 nuts are all inside the car so wont (should not) be rusty. The nuts on the fuel tank strap maybe but I have never had one that wont come off. Handbrake cables and brake pipes (1.6) or if a 1.9 I tend to unbolt and move the calipers out of the way to save bleeding them afterwards (if going back together as it was) :)
The leaving the brake pipes connected can also be done on the 1600 cars if just doing a straight swap, remove the drums, then you can unbolt the backplates complete from the trailing arm, and manoeuver the pipes etc round the trailing arm out of the way.
marksorrento205
I like it :)
Works a treat buddy, why disturb fully working brake hydraulics when it is the beam that is the problem you are doing the repair on!!
Its a bit more awkward than 1900 calipers, but can be done, the principle is the same.
Off topic but does anyone know if you can swap a Xsara VTS beam with the brakes still connected?
I vote no, due to all the compensator valve pipes and cr@p.
Having said that, I have done a couple of 206 GTI's, these have a union placed in a handy place that can easily be split and swapped onto the new beam, so you may be lucky.
That was my initial feeling when I had a look underneath but I thought I'd ask in case someone had managed it.
tartanbloke
Afternoon,
Removing the rear beam is easy even if you are doing it yourself. The hardest part is getting the new one on but a good trolley jack and some patience is a great thing to have.
If it is a 1.9, I would suggest giving the rear calipers a little bit of a refurb as the guides in mine were seized.
Chris
It can be done on a 306/xsara with the compensator :)
Paul_13
Yep, I've done it several times.
Excellent, I need to get on and do it really, tyres rubbing on inner arches is not a nice sound :o
crumbs, I've taken a few totally shot ones apart that didn't rub at all, dread to think how far through the tube that one has worn :blink:
It has a tow bar fitted, the previous owner towed a boat with it which I suspect didn't do it any favours.
jord294
i reckon your tube will resemble this
my old miami 309 gti had a towbar, and was used by a landscape gardener :wacko:
