gaz832
Help With Starting Issues.
gaz832
had bother trying to get the car to start for a bit now. i have power , fuel to engine, getting a good spark of all plugs. now the car is just cranking over , doesnt even seem like petrol is being injected into the engine to start. what should i look at first < could this just be a simple relay problem car is a mi16 by the way. brown and green relays in engine bay < could any of them be the fault. >
got power to the injectors?
gaz832
how do i check the power to them , i do think its a injector problem
multimeter or twst light, just turn the ignition on.
gaz832
ok thanks mate, what should the readings on all injectors < if i dont have power to them what should i go striaght to next.
battery voltage...
if you havent, check the relay.
Edited by welshpug
gaz832
battery voltage...
is it the brown relay thats for injectors.
