mikeyd 13 Posted July 25, 2011 is there any reason why i cant just remove the aircon rad and pipework leaving the pump to act as a tensioner[ it is on a 306 16v xsi autocross car] did a slalom and it runs hot with the crap in between the 2 rads and aircon is not wanted/working properly anyway!! Share this post Link to post Share on other sites
dcc 855 Posted July 25, 2011 you'll need to get it degassed properly, but yes you can remove it. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted July 25, 2011 If you are going to remove it I'd also lose the compressor, especially if you are autotesting, its a heavy lump. Share this post Link to post Share on other sites
ORB 227 1 Cars Posted July 25, 2011 Ohhh, are any parts swappable with 205 items??? Share this post Link to post Share on other sites
Ryan 99 Posted July 25, 2011 Ohhh, are any parts swappable with 205 items??? I don't think any of it is a direct swap. Share this post Link to post Share on other sites
mikeyd 13 Posted July 31, 2011 if i remove the pump is it just a case of fitting a non aircon belt or are there idlers/tensioners to fit as well? Share this post Link to post Share on other sites
marksorrento205 80 Posted July 31, 2011 If its like the gti6 ( which I cannot remember off the top of my head ) then yes you would need a belt, idle roller, a tension roller and a bolt to tension it. WP will know! Share this post Link to post Share on other sites
