rallyeash
Inaccurate Speedo
rallyeash
hello, my speedo seems to be very inaccurate. for example 22mph is just over 30 and 30 is like 45 or so. what are peoples thoughts on what this could be, speedo drive cable, drive unit in the box or the actual speedometer its self? running Be3 gearbox, gti dash clocks and cable.
thanks Ash
Are you running a matched pair of cogs in the speedo drive in the 'box, ideally both from a 205?
If you start mixing and muddling the gears up, the speedo gets very inaccurate.
Generally, 205 speedos are very good in my experience - I know my white '89 GTi is pretty much bang on when compared to the GPS.
rallyeash
standard 1.9 gearbox just fitted with a quiafe so should be standard 1.9 drive in the box.
yeah my mates speedo is bang on with the GPS also
do you have those clocks spare? want to get my rev counter working and fuel gauge. :)
Ryan
What size wheels/tyres are you using?
Dan!
Have your clocks ever been taken apart? If they have, the needle for the speedo might not have been put back on properly. If its linearly wrong i.e 10mph out at 20mph, and only 11/12 mph out at 70 then moving the needle should make it alot better.
Also, non standard wheels/tyre sizes? :)
rallyeash
185 55R14 Yokohama A048's
im trying to source a good set of dials from anthony as the rev counter sometimes works and sometimes doesn't so want another set of dials and do the tacho mod too it.
doesnt seem to stay a fixed speed out, although ive only compared is at low speeds
Edited by rallyeash
SurGie
Yeah and the GPS systems are also accurate as well :rolleyes:
I would replace both speedo cogs with a new speedo cable. Then renew the speedo housing seal as this causes many gearbox oil leaks.
Hope this helps :)
should be on 185 60 not 55 :)
rallyeash
it was on 185 60 R14 toyo R888's but there wasnt stock so got a special price on 185 55 R14 A048's instead. although this made no difference to the speedo but gave me less tyre wall flex :)
theres one of those things which flash up your speed on a local road atm and the speedo had to read about 22 to be 30-31 mph so i know its out!
Bakes100
When i had a 6 speed box in my old 205 the speedo read approx 15% too high. I fitted a different plastic speedo cog into the gearbox housing and after that it was fine. Off the top of my head I cant remember which one i used but there is (was) a large selection available from peugeot, which i think are all different colours depending on the amount of cogs
Hope this helps!
Weser
I changed my dash clocks once to another second hand set and the speedo was out but 10mph. I.e 20mph indicated was 30mph actual. Bit annoying. I just replaced with another set of clocks and that solved the problem. It depends if like me you know that everything else is ok on the car?
marksorrento205
Unless im missing something, your running a 1.9 gti gearbox with 185-55-14 tyres. As the 1.9 runs 195-55-15 tyres that cant help as the gears in the speedo drive are for 1.9 wheel radius or am im missing something??
When I had my vts box on my 6 engine I fitted the 1.9 speedo drive parts with the correct size tyres and the speedo was bob on. Also when I first returned the 306 rallye back to standard cyclones ( and ditched the hidious 17's it cae with) they came with 195-45-15 tyres on them and the speedo over read by around 10 mph. 50 profile ones brought it down a touch and the std 55 profile is now within 2 mph.
1.9 GTi is 185/55R15's as standard - I suspect you're thinking either of 306's which run 195/55R15's, or the fact that most people run 195/50R15's on 1.9's.
rallyeash
the 185 60 14 r888's i had on the front recently were still the same speedo reading and i lined them up against an old 195 50 r15 r888 and were pretty much the same diameter. my mates got these fitted on his 1.9 205 and there spot on on the speedo reading
still ok to collect the speedo dials later anthony?
marksorrento205
185-55-15 is what I have got :lol: A slight typo :)
Edited by marksorrento205
Tesstuff
No wonder you think it's quick if it's showing that much more on the speedo for that given speed :)
Your choice of tyres/wheels is only making a -4.65% difference on the 1.9 box. So at 30 it would be showing on the speedo as 31.39 which is neither here nor there.
So your problem isn't a rolling radius discrepancy.
rallyeash
haha :lol:
its annoying if driving through a 30 with a speed camera in place or somthing similar. i can appreciate it could be 5% or so out because of the different radius but not 10mph+ at such low speeds.
picking a new set of dials up from anthony later which im hoping does the trick. also rev counter tends to drop off when accelerating then comes back when the throttles let off. going to do the mod again and hopefully sort that too..
Grim.Badger
It will be the small cog in the speedo housing - I'll bet you have a red 17 tooth cog, which is the one that the parts catalogue says you should have, and if you change to the 21 tooth cog your speedo will read right. I had the same problem with my old 1.6 with exactly the same miss-read; it seems that the "innacurate" clocks aren't actually broken but are set up for a different speedo cog than the "working" ones.
The cogs were about £6 and a 10 mintue job to change if you fancy trying it.
rallyeash
i changed my clocks now, theres definatly a difference, 30 feels about right now but it feels like its over reading at 70+. going to stick sat nav in it and take it for a spin i think
Tesstuff
Can't wait for the video of you doing 30 showing 30 rather than 45 at 30 :)
So excited :D
rallyeash
So excited :D
:lol:
Edited by rallyeash
Redtop
Is this a track day car? If it is then why not get a trip meter like a monit and then calibrate the speed accurately yourself. Then you would know exactly what speed you were doing, with the size of wheels your running :) .
