Daz_C
Fuel Sender Resistances
Daz_C
I'm just in the process of fitting an aftermarket fuel gauge and to calibrate it to my original sender I need to know what the resistance in ohms is ?
If anybody knows that would be great.
Daz,
I've found the part number for the sender (0 986 580 238 ) on the bosch ecat but can't (or haven't yet) fopund anymore info.
Graham.
Daz_C
O.k thanks anyway, I've sorted it now by performing a manual calibration, seems to be o.k, I'll carry a jerry can till I can be 100%.
EdCherry
Can you post up your results for us that also would like to do a similar thing?
Daz_C
The only results I can give is that non of the resistance ranges listed below seemed to work with the sender.
73 - 10 ohms
16 - 158 ohms
0 - 30 ohms
0 - 90 ohms
240 - 33 ohms
107.5 - 7 ohms
131 -12 ohms
Custom Calibration
Some of them seemed to work initially but then started to creep up or down the others read wrong compared to the amount of fuel I had in the tank.
Custom calibration seemed my only option which envolved (for me) removing the sender from tank, putting a drop of fuel in an empty Nescafe jar, other jars are available ^_^
I did as the instructions stated and hey presto. I filled the jar to approx inch and a half over the base of the sender to be sure I had a reserve amount in the tank when it says empty.
My gauge is a Stack (programmable) Fuel level Gauge.
I'll carry jerry can for a while jsut to be sure.
EdCherry
Fair enough, I was tempted to run fuel level on my Race Technology Dash2 and wondered if you could make it easier thats all! Will do the same with mine and just input it all into the maths channel cheers mate!
brumster
I've just measured a sender as pulled from a 1.6 GTi (G-reg fwiw) and I get :-
Float at top - ~13 ohms
Float at bottom - ~270 ohms
Roughly in middle - 100 ohms
That's measured directly on the pins of the sender, and out of the tank.
