TaffyTim 6 Posted April 25, 2011 A bit of a basic question here, but if you dont ask you dont know. When a wire goes into a multiplug such as the infamous brown multiplug are the wires held for life or is there a certain knack to releasing them? Share this post Link to post Share on other sites
smithy 1 Posted April 25, 2011 A bit of a basic question here, but if you dont ask you dont know. When a wire goes into a multiplug such as the infamous brown multiplug are the wires held for life or is there a certain knack to releasing them? they can be removed there will be a little tag on the crimp that holds it in the plastic plug,some are easier than others to unclip so wire can be pulled out. Share this post Link to post Share on other sites
TaffyTim 6 Posted April 25, 2011 they can be removed there will be a little tag on the crimp that holds it in the plastic plug,some are easier than others to unclip so wire can be pulled out. Is it a needle nose pliers job or more of a hooked tool? Share this post Link to post Share on other sites
Pugs in Pieces 0 Posted April 25, 2011 if my memory serves me correctly you can use a small screwdriver on the side where the terminal is (not the side where the wires come out), there is a small tab/tag that needs to be pushed to one side and then pulled out from the cable side. the terminal stays on the cable and pulls thro. hope that makes sense. Share this post Link to post Share on other sites
welshpug 1,737 Posted April 25, 2011 (edited) if its the brown multiplug non-insulated type, then here's some image links from my photobucket. male plug - Female plug Edited April 25, 2011 by welshpug Share this post Link to post Share on other sites
TaffyTim 6 Posted April 25, 2011 ta welshpug, very useful as always. Funnily I worked this out when i was tinkering today. I still dont know for certain how the wires are connected to the terminals. I guess that the terminals are provided with the plug and a simple crimp attaches the wire to them? Share this post Link to post Share on other sites
TaffyTim 6 Posted April 27, 2011 Where can you buy these types of plugs from? I tried Halfords and Maplins yesterday and they both drew a blank. Im redoing the starter wiring and i only need to change one pin, is it possible just to buy the terminal that sits in the plug? If so where should i be looking? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 27, 2011 Afaik the terminals are available from peugeot only, a few people on here have managed to get them before (Anthony & Spikey iirc). Can't help with the numbers atm but will have a look. Graham. Share this post Link to post Share on other sites
rallysteve 22 Posted April 27, 2011 I have been searching for these for ages, after trawling through hundereds of different terminals from RS etc I could only find one possible match but wasnt willing to pay the large cost of buying 1000 of them. Might I suggest you replace the whole connector block with either fixed connections or if you want to be able to unplug, buy a complete connector from Vehicle wiring products or similar. Cheers Steve Share this post Link to post Share on other sites
TaffyTim 6 Posted April 27, 2011 I have been searching for these for ages, after trawling through hundereds of different terminals from RS etc I could only find one possible match but wasnt willing to pay the large cost of buying 1000 of them. Might I suggest you replace the whole connector block with either fixed connections or if you want to be able to unplug, buy a complete connector from Vehicle wiring products or similar. Cheers Steve Ah thanks for that, i spent about an hour searching online this morning with no success, so I thought i was just being a bit dumb and not looking in the right places. Share this post Link to post Share on other sites
P_Monty 2 Posted May 22, 2011 It might be worth a look at these: http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/noninsblades.php I fixed my sidelights with something from here. It wasn't an exact match, but was close enough... Share this post Link to post Share on other sites
