JR20516V
What Are The Xantia Ct Turbo Gear Ratios?
JR20516V
Also trying to find the final drive regarding this car. I have Googled and get conflicting info. Anybody have them handy ?
Cheers Guys
This is what I have. Source is reputable - Hilgert
Xantia V6 / 406 V6 (ML5T)
1st 3.251
2nd 1.783
3rd 1.194
4th 0.875
5th 0.702
FD 4.314
Xantia 2.0T (ML5T):
1st 3.250
2nd 1.783
3rd 1.194
4th 0.875
5th 0.702
FD 4.478
Hmm, interesting as the CWP on the 406 Turbo engine was the same as the V6 one, cannot recall what is was now thou
JR20516V
Thats exactly the figures i have Peter.....but there are some completely different ones on the Google machine. That gives me something to work on now and i really appreciate your info.
Which would you change in this box for the 2.0 8v application? Also the final drive choice would make a vast difference here....so can you suggest the best FD which can be sourced in OZ [unfortunately we dont have the 205 diesel fd's here :{
At the moment i am thinking simply using the standard BE3 box with a Mi16 5th ratio....yes/no?
This is the M series box so a 205 CWP won't fit or anything else from the B range
Henry Yorke
BE3 Mi 16 box with a 1.9 final drive. You get the standard 1.9 gearing on 1,2 and 3 and a longer 4 and 5. I run this on my 1.9 Turbo and am at 70mph at 3200 rpm which is just below the boost coming in when in 5th, so cruises well.
JR20516V
Thanx Miles and Henry for the great tips.
Just one thing..... i thought the BE3 box from the Mi16 was the same ratios as the BE3 box in the 205 ??? yes/no?
Maybe the same final drive too....4.43 ???
Cheers John
Jamal
Well in my docs the TCT final drive is 4.214
On my TCT I use the Mi16 gears with 1.9GTi final drive too.
JR20516V
Thanks for that Jamal....that seems to be the go i think. :}
JR20516V
.....just read your project thread....great stuff !!
