Mart Pug
Where On Gearbox Is Gearbox Code?
Mart Pug
This search doesn't seem to reveal the answer:
Search
So where exactly is the gearbox code on BE1s? I was hoping to determine whether mine is a 1.9 or 1.6 as it certainly feels quite short, but do not have any record of it vein changed.
I know on the MA boxes it's on the side, on a flat part of the box.
Maybe the surface of mine is so too blemished to decipher...
Its a sticker on the older gearboxes, so more than likely not there any longer, they are near the diff casing on a flat machined part of the casing.
large
AFAIK you have to look at the numbers stamped on the crown wheel to be 100%
link
Edited by large
link
That will only tell you the final drive ratio but should give you a decent idea of which box it is,
Graham.
Mart Pug
Thanks. Yeah I think the sticker must have come off at some point in the last 22 years!
Will have a look when it's comes to clutch time.
streetsleeper
is'nt the be1 box with the lift up reverse next to first?
Yes but that's not what the op was asking about imo, more the rpm / speed in gears between the 1.6 & 1.9 box.
Graham.
Mart Pug
Correct, Graham.
I know it's a BE1 but the ratios feel decidedly short. But this is my first 205 so I don't have a reference point.
Another way of telling might be if I tell you my rpm in fifth at, say, 50mph. Would that be enough info to determine whether it's a 1.6 or 1.9 box?
If you're running standard sized tyres yes, 1.6 is 18.9mph / 1000rpm in fifth & 1.9 is 20.9 iirc.
Graham.
Daviewonder
Graham.
Am I right in saying the tyre size wouldn't affect the gauge readings, only the actual speed?
Kinda, a larger overall tyre & wheel size will alter the speedo reading & in turn the rpm will differ slightly but not by a miassive amount on either count unless you have changed the ratio massively.
Graham.
