Iain-gti
Rust :(
Iain-gti
Hi,
There is rust along the bottom edge of the windscreen, not sure how to fix it. Anyone got any ideas??
Thanks Iain
remove the screen and treat the rust however suitable, be it rub down prime and paint, or cut out rot and weld in new steel.
Edited by welshpug
Iain-gti
Thought you may say remove windscreen. Trying not to remove windscreen as its a pain to refit. I hoping there would be a in genius plan. :P
yeah, get someone else to remove the screen, its not difficult on the 205 as it is not bonded.
Iain-gti
Like who?? company?
omega
do it yourself its easy.
Stevo309
Hit it with a hammer, fix the rust then call your insurance company and get them to come and install a new one :P
Iain-gti
I can remove it, doing it Rambo style :P. But refitting is the tricky bit.
Masekwm
String
mickie
its harder to remove than refit.. honestly its soo easy to fit a 205 windscreen
pugpete1108
agreed, its far easier to refit than remove. i shmashed mine trying to remove it. good job it was cracked already hence why it was being removed
Jrod
Fold the rubber back and jam 2ps in between the seal and the actual frame, do this all the way along the top until you can get a corner out then it just slides out.
Easy!
SurGie
Easy!
Do you mean put the 2p's from inside the car ?
Jrod
Yes, If you try it and have a bit of common sense you'll figure out exactly what I mean. :ph34r:
Edited by Jrod
harryskid
If your well off, try 50ps :ph34r:
MerlinGTI
  Jrod said:
Yes, If you try it and have a bit of common sense you'll figure out exactly what I mean. :mellow:
  harryskid said:
If your well off, try 50ps -_-
I love this forum <_<
the 2p idea is mint too :lol:
