Will Eastman 6 Posted January 3, 2011 My heater fan descided to stop working recently, so i started faffing about testing the fan worked sing a different power source (it did) n messing about with the circuitboard thing behind the control knobs. Having no luck i did a search and found that a common fault is the resistor thing, so i took this out (it looked pretty nakered) and replaced it. But now the heater still doesnt work. What else could it be? One thing i noticed is that the resistor that i took out had 4 pins on the conector, and the one i put in had 5. Oh and my stero wont turn on or anything, dont know if this could be related (fuses look fine) thanks Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted January 3, 2011 You checked your heater matrix isn't leaking? Share this post Link to post Share on other sites
Will Eastman 6 Posted January 3, 2011 No but its not there heat thats the probleme its the fan. Would this stop the fan working? Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted January 3, 2011 You mentioned your radio has also stopped working, so if the matrix was leaking, it could have shorted it out. Share this post Link to post Share on other sites
Will Eastman 6 Posted January 3, 2011 Ahh i see, how can i check if its leaking then, im guessing just pull out some of the dash n have a feel. Thats unless there is a top-up tanks that i can look at to see if its empty. thanks Share this post Link to post Share on other sites
tomcolinjones 26 Posted January 3, 2011 Ahh i see, how can i check if its leaking then, im guessing just pull out some of the dash n have a feel. Thats unless there is a top-up tanks that i can look at to see if its empty. thanks it is the engine coolant in teh heater matrix, i would definately check it if i where you. you could pull up some carpet and see if the underlay is wet? Share this post Link to post Share on other sites
Will Eastman 6 Posted January 3, 2011 Hey thanks for the help, just been out for abit of a fiddle and there isnt any sign of leaking. I also re-checked the fan, and its is very dodgy, it is very intermitent, and thats when just connecting it to an exterior power source (not the resistor). Any more ideas on the stero not working, could i have blown something in it when i jump started the car recently? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 3, 2011 I find it hard to believe you could've done any damage while jump starting the car but how far & what did you take apart when you stripped the dash bits down? There is a copper sprung wiper that crosses the tracks on the circuit board that is easily lost & stops it rom working. Graham. Share this post Link to post Share on other sites
