Iain-gti
Instant Gasket
Iain-gti
Hi,
anyone recommend an instant gasket, I have used a black one before which is good but can remember the name of it.
Thanks Iain
I'd recommend Wurth's RTV :lol:
Paul Smith
Loctite is black and the best I've used
Iain-gti
RTV thats the one!!!!!!!
cheers welshpug
daza4
If you want any im a wurth rep :D
likewise for any wurth products I can supply them !!
PM me
Daza
How much can you supply the 3L fluid brake cleaner for?
daza4
If you have 4 they are £5.99 each. + P&P
I'm assuming you mean the aerosols? I mean the 3 LITRE bulk brake cleaner to go in the Wurth refillable pump spray bottle.
Although if it is £5.99 each for the 3 Litre then I'll have 10 please!!!!!!!!!
daza4
No Tom i mean the 3ltr containers, if u buy 4 or more i can do them for 5.99 each, so 4x 5.99 +vat plus p&p
send me a pm if u want some :lol:
Daza
JRL
hope you dont mind me hijacking but on the subject of gasket sealant will this stuff be suitable for a standard mi16 throttle body gasket? or do peugeot still do the correct gasket?
joe1joe
with my experiance i have used many diffrent sealers, the silicone peugeot sale is pretty good.
but i now just use normal motor fators rtv in a chauk type gun and its cheap!
and i havnt had any leaks with the cheap stuff, think its usualy down to the prep.
S@m
Peugeot don't do the throttle body gasket anymore, assuming you mean the 1.9 mi16. I cannot comment on using instant gasket, the only alternative i have found is the ptfe gaskets on ebay (but i haven't tried one).
Sam
that's normally black Loctite with their cut added :P
Alan_M
Sam
I managed to get one from Pug Wokingham, no problems.
Redtop
  welshpug said:
that's normally black Loctite with their cut added :)
Yeah just has a pug part number on it Mei. Not bad stuff. The sealer I use on all my cars is a Toyota one. It's in a small tube and is £73 inc vat!! It never fails and when your doing timing chain covers the last thing you want is for the thing to leak after you've had the engine out! Most of wurths stuff is very good just abit harder to get over here. Is there actual Wurth shops in England or just reps?
quite rare to see any in the shops, usually found from reps (daza4 happens to be one as mentioned earlier :lol: ) or on ebay!
much like snapon and mac in that respect.
Edited by welshpug
Redtop
It's a rep that come round to us the odd time. Thought maybe there was shops in the mainland as there is an actual 'Wurth shop' that ive been in, in Portugal.
There are actually a number of Wurth shops around, about half a dozen in the UK. My local factor also does carry a few selected Wurth products, including the black silicone, which is where I buy mine from.
All Praise The GTI
we use wynns black gasket maker at work. comes in a pressurised can :lol: withstands constant 260c i think
S@m
I work for citroen and they are definetly NFP, part number 163565. I suppose pug in wokingham must've had one in stock! lucky find!!
Sam
