iamjackiechan
Pic Request Please
iamjackiechan
Hi
Hopefully one day I will get this sorted.
I was wondering if the thicker rod that goes from the gearstick to the ball joint on the subframe is the same for tu and xu
Pics would be appreciated.
Will
tomcolinjones
  iamjackiechan said:
Hi
Will
would also like to know peolpe, have swaped over subframes and it seems to fit, but havnt got box in to see if its in the right place!
iamjackiechan
I could swap subframes but then I would need to change to single point wishbones etc, I'd rather stick with what I've got and try and make it work. I spent most of yesterday playing around and modding tu and xu gear linkages to try and make something work and I got a few gears.
Just need to know if I need to change the bigger rod because it doesn't line up quite right
Will
swordfish210
I don't have a pic but i am pretty sure they are different.
XU and TU are different on every linkage going
