blessed6383 0 Posted September 12, 2010 have wired my bx loom in this morning but seems to have no ignition amp or coil wires to put in any ideas? have made a seperate loom for sensors, starter/ alternator etc but what should i do about the others? Share this post Link to post Share on other sites
Anthony 1,003 Posted September 12, 2010 The ignition amp and coil bits are on a seperate plug-in section on BX looms - did you not get this with the loom? Share this post Link to post Share on other sites
hexhamstu 9 Posted September 12, 2010 It's as anthony says there are 2 parts to the loom, I can take photos of my BX loom tomorrow showing the 2 parts if you want? Share this post Link to post Share on other sites
hexhamstu 9 Posted September 12, 2010 Found a picture I took of it ages ago. Share this post Link to post Share on other sites
blessed6383 0 Posted September 12, 2010 didn't get this bit so will now need it aswell, cheers for the info guys also bit stuck with the under dash wiring 1. Blue wire with spade connector = permanant 12V = have this wired in to shunt box 2. Yellow wire near the ECU = fuel pump = have this wired up to 76 white wire 3. Yellow wire in a white 2-pin plug = Switched 12v = ? 4. Green wire in the same plug = rev-counter. = ? only green and yellow wires i have found are going into a white plug at end of loom near afm plug any help guys as im fuc*ed if i know as not sure if have other bits of wiring missing? cheers Share this post Link to post Share on other sites
jackherer 543 Posted September 12, 2010 The two wires you can't find are on the bit of loom you don't have. You can see the plug in Stu's pic above. Share this post Link to post Share on other sites
