Spiky
205 Gti6 With 6 Speed Box Change
Spiky
hi,
changing a 206 gti6 running a gti6 box to a be3 205 1.9 box
things i need to change?
gear rods?
gear selecter arm from gear stick?
Masekwm
Clutch kit and cable set up, the rest should be as it was irc.
If you want to retain the '6 Clutch then I guess it would be the opposite of fitting a Xsara box, so you'd fit the 306 clutch arm & bits.
You did mean 205 GTi6?
blessed6383
if you do a search on fitting a 6 box in a 205 its just the reversal mate
Edited by blessed6383
Spiky
yeah sorry meant 205 gti6
changing to mi16 clutch is needed isn't it? as the be3 wont work with the gti6 clutch?
blessed6383
yes mate your need a mi16 clutch
Masekwm
You could just swap the '6 box for a Xsara one
Spiky
yeah, been searching too
mi16 clutch
be3 selectar arm
be3 clutch arm
be3 gearstick?
that it?
Edited by Spiky
Spiky
we could, but mate has bought a rebuilt box and contains a diff
we hoping "6" box is a later one, else we need drive shaft
if it has a "diff" then you wont have driveshaft issues afaik
be3 will work with a gti6 clutch, gti6 is a BE3....
if the work to make the gti6 box work in a 205 has been done, just transfer the clutch arm to the new box, saves buying a new MI16 clutch
Edited by welshpug
Spiky
what is it running at the moment?
full gti6 setup in a 205 engine and box...
blessed6383
dont think your need to change the gearstick as canged my mi16 to '6' box and using standard gearstick
see edit!
Spiky
where was your reverse? as this has a lift up like a be1
blessed6383
ah maybe then as mines a ph2
all BE 205 gearsticks are the same.
blessed6383
there all seleved with lift reverse? did think so
Spiky
sweet, so just need the clutch arm
and so no need to change gear stick,
but just the gear selector arm? or is that fine too?
this all sounds to easy..lol
the arm on the box will need to be a 205 one, just change it for the one off the box in the car, same as the clutch arm unless yuo want to keep that on there for selling it on.
in that case a TD arm will do as they are pull type too.
all 205 gearsticks are the same, what is on the top or around the shaft differs yes, but the stick is the same.
Spiky
cheers for the info :)
less work than we though :D
yeah it sounds like it if the work to make a gti6 box fit in a 205 has already been done :)
But why a 1.9 box, LOL.
But as said just swap everything from the old box to the neew one, Job done.
Thou is the N.S shaft is the 306 one or like a few do chop it down then I would get a new one to ensure the splines lock in
Spiky
your right, what a stupid idea :)
may i bring your attention to the following thread
http://www.306gti6.com/forum/showthread.ph...0&page=last
so the splines are the same, just longer on the 306? he's quite prepared to purchase new shaft
Splines are shorter on the 06's, thats why some companies (Up North) cut them down which when you come to change the shaft makes it a complete pigs ear to do.
Spiky
I'm sure you can work it out
