johnhenry
Possible Head Gasket
johnhenry
Right
i was finally getting towards the end of its troubles and then this...
It just felt different pulling out of a car park earlier (i have a fear of constant HG failure thanks to pugs) , then the temp was reading much higher than normal in traffic
Got it home, then started reading up on HG failure and saw the test for it, fill up the coolant reservoir to the brim and then turn the engine on,
there was virtually no water in there in the first place (filled it up about 5 weeks ago)
then bubbles, not consistantly but bubbles fairly large jus kept coming till the car was virtually up to full operating temp...
oh and on start up (it was already warm) there was a bit of white smoke; just a small amount that kepts coming out until just before i turned it off
i opened the bleed screw (i cant see any others) by the bulk head and thats ok, water coming straight out no air)
i cant think what else it can be
Is there a good guide for doing the job anywhere?
Cheers John
johnhenry
ok ive had another good look and root around, bled the coolant system again.
theres no water in the oil that i can see (on the dip stick and the oil filler area.
there are air bubbles coming up through the expansion tank.
ive read about some sort of membrane when knackered letting air in??
sorry to bump the topic but i neeed to sort this very sooon
choochoo
Shame you wasnt closer to me i could of replaced ur head gasket cheap . would of included a head skim and pressure test too
harryskid
Does the white smoke keep going?
johnhenry
how much would you look at for all that man? i got a few mates with 4x4's n trailers
nah the white smoke stops.
choochoo
would have to price up a head gasket set and head bolts first . could do this monday for you if you want
johnhenry
regarding price of parts: £35ish for cylinder headgasket set
can i let you know tomorow man? gona get a compression tester on it and see what its readings are, also gonna see if its anything to do with an advanced diaphragm or something, seems to share similar symptoms as well.
regarding condition, this is a very precautionary job, its not overheated yet, just displaying symptoms of Possible HG failure.
Fox
I'd scrap it.
Only kidding, although it does sound like HG failure, if your handy with the spanners a days work should sort it, for a £13 gasket I'd skip the skim and risk it...
hcmini1989
Right do a compression test on all cylinders then do a pressure test on water system if these come back ok try a sniffer test .Is the water system over pressurising start it up let it warm up with the cap on and squeeze the water pipes see how hard they are .If they are solid there is a problem if they are abit pressurised it should be ok .Does your cooling fan work ,Is the thermostat working ok
If you dont have any of this equipment above take it to a garage and pay them to test it all for you .If its a decent garage they wont charge you any more than £30 to test it all for you then if it is gone get the work done by a freind or tackle it your self not a big job .Im sure theres enough info on here if you search to guide you through it.
And id at least get it pressure test it as stated above not worth the risk of putting it back together if the head is knackerd
Edited by hcmini1989
Never as cheap as you first think I'm afraid so be carefull,
It does sound like the H/G failure but when the heads off you may as well check the valve guides (Known for wearing out) replace stem seals and re-shim the cam, soon your knocking on £350.00 before labour
johnhenry
I'd scrap it.
im fairly competent with spanners, just terrified (mainly cus of my stepdad who's managed to put the fear of god into me) about wet lined engines, is there any guide/step by step help i can find anywhere, ive had a good look around on here.
its in good nick, hasnt overheated, so doubt the heads warped
im looking a head gasket set, what else is there in there other than a HG? like other gaskets and stuff?
I'de scrap it...very tempting at times ;) but im well and truely on this emotional rollercoaster now, too late to get off it now!
Edited by johnhenry
hcmini1989
Search mate its all out there
Dont worry about wet liners just dont turn the engine while the head is off you should be ok
johnhenry
many thanks everyone! i dont have and of the items needed to test compression, pressures etc etc or have any idea how to/what is a sniffer test!
ill pop it down to a friend at a garage and will get that done. maybe look at mid week being in a position or sorting the whole thing out.
ill post when i know more!
Cheers John
hcmini1989
Cheers John
Its the best thing to do mate save buying all the tools
A sniffer test -you hold it over the header tank (with the cap off) create a seal around the top of the tank with it and it has a liquid in it so when you sqieeze a little rubber diaphram thingy it sucks air in and if the liquid changes colour there is exhaust gas or combustion gas in the water system meaning the HG is gone
sorry about the description sounds weird but you`d have to see one in action really simple
dobbo26
Hi if you do have the hg done have it skimmed at the same time for the cost of it as it might save you having to do the job twice.
choochoo
If you do it yourself you be amazed how easy it is once u got the inlet manifold off as theres realy not alot on these engines
johnhenry
well my friends dad is a mechanic so im gona take it up there and see what the deal is with it
looking into something called a advanced diaphragm as a similar member (tomwp) posted a thread showing similar symptoms and it was that, not HG.
drove it 10 miles each way to work today, didnt have any temp problems, but i know/have seen air coming through the header tank.
will post more on this after i get diagnostic stuff back
many thanks again
johnhenry
Checked the advanced diaphragm, its knackered.
Firstly; this shares some of the symptoms of whats up with mine, but not others, uses water fast and seems down on power,
> is this going to account for air getting into the coolant?
If yes: anyone know any suitable fits? saw pugtorque saying old fiesta ones do the job fine as they (pug ones) aren't made anymore.
If no: HG will be gone then for sure, that was the only other option of what could be it.
GLPoomobile
I'm assuming you are talking about the vacuum advance that is in the distributor. This has nothing to do with the coolant system, so it will have nothing to do with bubbles in the coolant. It will account for lacklustre performance (as will pretty much any important engine component that fails) as when it's not working it can't advance the distributor when it needs to, meaning the timing is out under certain conditions.
johnhenry
yea thats the part i was on about, after abit of thought i realised they couldnt be anything to do with each other yeh that was me being novice again.
essentially the list (again :/ ) of parts it needs
Head gasket
Vacuum Advance Diaphragm
starter motor
Fan Heater
well thats next week sorted then!
will keep all posted on the HG position.
lemmingzappa
I've been looking for one of these for my 1.6 and have had no luck so far. Peugeot no longer have them, and a Bosch dealer I tried no longer have them.
Someone mentioned using an old fiesta one, haven't found any on eBay though...and the trouble is the 1.9 and 1.6 vacuums are different lengths :D
Edited by lemmingzappa
2-Pugs
The trouble with the head gasket job, as I hope you won't find out, is all down to the head bolts. If they come straight out then you're almost home and dry. Just take your time, follow Haynes, take the opportunity to get it skimmed and fit a new cambelt too. It's all fairly straightforward. If any of the bolts snap, though, you're in for a world of pain unfortunately. Sure there are ways around but its a ballache you don't need.
Edited by 2-Pugs
johnhenry
Right i got it sniffer tested: where can you one of those things? they are awsome!
yeh HG failure. :(
got parts for it at good prices, gasket set and head bolts, picking them up 2moro, going to get the head off wednesday with my friend: toyota mechanic (thank god) gona chuck loads of new parts on it then as well, all sorted.
Regarding removing the headbolts, are there any tips other than take your time, im getting a nice deep impact 6 sided socket for them and an extra bar for my socket set, so can control the force applied better. applied some 3-1spray oil to them tonight and gonna do it again 2moro morning before work and when i get home, should help a lil bit i guess!
ORB
6 Sided impact socket?
You need a Torx 55 mate.
harryskid
While we are talking head bolts i'am trying to get the head off my old 1900 and the first bolt came out alright but the second broke my torex . Am i doing some thing wrong, the bolts seem really tight. Any tips? :(
