spicer
Starter Motor Problems
spicer
after 2 years i thought it was about time i sorted my starter lol
when you go to start it it just keeps clicking ( which is now getting worse) but will eventually start
i read on here somewhere about wiring in a relay have tried searching but can't find it , can anyone throw any light on it
cheers mark
rory1
Hi
the brown multi plug is a common fault for non starting would be worth looking at that
spicer
cheers for that will have a look but would still like info on wiring relay
Cheers mark
Wes
mine does this aswell. i have repaired the brown plug a while ago when i did the head gasket and made no difference to the starter.
"Repairing" the brown multiplug is pretty hopeless frankly, as usually not only is the plug itself in a mess, but the wiring either side is badly corroded and oxidized. You really need to chop out the brown multiplug and a 6-12" wire as a minimum, and run fresh wire down to the starter (and the other sensors while you're there) with new spade connectors. Ideally, run fresh wire all the way back to the underdash plugs thus making a fresh sensor loom.
Wiring in a relay isn't too difficult to do and I can scribble out a wiring diagram if you like, but I've never found a time when it was needed - a relay is fixing the symptom, not the underlying cause.
Basically, you need the original starter solenoid feed to one side of the low voltage side of the relay, and the other side earthed. On the high current side of the relay, you want a fused feed straight from the battery one side, and the other goes to the starter solenoid wire.
Hope that makes sense :wacko:
Oh, and the other point of note is that the original bulky starter motors are much more prone to clicking than the later slimline Valeo starters found on various late 90's Peugeot and Citroen models.
spicer
Cheers anthony a quick diagram would be a help and i'm also running a 90's slimline starter
Here you go Mark:
Hope that helps :wacko:
The other item is the ignition switch, I;ve replaced a couple of these to sort the clicky clicky syndrome with good success, Not cheap thou
