205*31*
Cam Cover Removal
205*31*
Hi I want to remove the cam cover to check all the rocker bolts are tight and have a general inspection, I am presuming I will sealant and will I need another gasket when putting back on? also are the cover bolts torqued up to a spec?
cheers.
Ryan
The gasket is rubber and can be reused. I reused mine a couple of time anyway and never had any leaks.
Torque is 10Nm (7 lb ft).
205*31*
Thanks ryan :D
And you don't have rocker's unless a TU engine :D
