Obey_R
Is This Indicator Broken?
Obey_R
The headlight is loose on the n/s, so I had a look at where it connects to the indicator and I'm not sure if all of the 'holding bits' are there or has some of it snapped off? Can't compare it to the otherside because that one is broken.
Edited by Obey_R
jason7579
Looks like you're missing a little bit, a sort of triangular catch behind the metal clip.
Obey_R
Hmm, think I'll just get a new pair anyawy - if I'm replacing one...
Obey_R
Just looking at that picture Jason posted... Are the headlights meant to fix into the indicators?
I have a 1992 1.6 and the only way the headlights are held in is by spring clips on the indicator and next to the grille... but looking at the picture above that indicator doesn't look to have those clips, or anywhere for the headlight notch to sit....
Help?
