JackTar 0 Posted May 18, 2010 Aaaaarrrghhhhh! I feel marginally better now. After trying to remove an almost pristine radiator from a 1.9, the connection leading from the expansion tank to the left hand top of the radiator (as you look into the engine bay) has snapped off. Can someone please tell me that this may be repaired? Why did Peugeot use those hose clips that clearly leave you with no method of undoing them? Share this post Link to post Share on other sites
luggy 13 Posted May 18, 2010 Ive previously used superglue to reaffix as an emergency temp repair. Share this post Link to post Share on other sites
powermandan 0 Posted May 18, 2010 Ive previously used superglue to reaffix as an emergency temp repair. You can get this epoxy based putty which i would imagine would solve your problem, milliput springs to mind. i once used it to repair a sump with a hole in it in an emergency Share this post Link to post Share on other sites
jackherer 543 Posted May 19, 2010 Epoxy resin such as Araldite is perfect for repairing the take off you're talking about, as well as any other radiator damage. I've used it myself successfully on a 406 V6 with that takeoff snapped as the rads for them are very expensive. Share this post Link to post Share on other sites
timb1046 1 Posted May 19, 2010 i had the same problem about a month ago, i used araldite to repair it, it worked fine. i put a long bolt through the hold when i glued it all together to stop glue blocking the water way entirely and then just pulled the bolt out once the glue was basicaly dry. worked a treat Share this post Link to post Share on other sites
Baz 421 Posted May 19, 2010 Try and find a small piece of pipe to fit inside to act as a strengthener, then as above glue/bond it back together for a permanent fix. Share this post Link to post Share on other sites
JackTar 0 Posted May 19, 2010 Thanks fellas - I'll give it a try this weekend. Share this post Link to post Share on other sites
