Guest 20dizzle5 gti
Lowering My 205 Gti
Guest 20dizzle5 gti
hi just woundering if anyone can help me on the lowering of my car i just need to no whats the lowest i can lower it without doing any mods to the wheel archs thank :)
Guest 20dizzle5 gti
thanks but lowering front aswell :)
blessed6383
i think each spline movement is either 23mm or 27mm correct me if im wrong guys when i lowered my old 205 gti i dropped the front 60mm ond if i remember correctly 2 splines on the rear and this look very smart and looked about level double check on the measurement per spline tho before doing or may have to do twice lol also well worth replacing the trailing arm bearing when your doing this as only cheap and can save a knackered rear axle later on hich is not what you want
blessed6383
also mate wouldn't go any lower than 60mm as thatwas a pain with the speed bumps altho did stick to the road and no arch mos needed for a 60mm drop
Edited by blessed6383
no, each spline movement is closer to 2.5mm or so.
Guest 20dizzle5 gti
thanks guys and ok if its 2.5 how many spines to get a 60mm drop ?
With the torsion bar spines fully clear of the beam tube & radius arm, use a dummy shock to set the distance between the bolt centres & rotate the torsion bars one spline at a time until the splines push home.
They are a vernier spline with different number of splines each end so you can make almost millimetre changes.
Simes
60mm will handle like a dog.
Drop it around 30mm and you'll be on the way to car that handles well.
Rob Thomson
I thought you started with a car that handles well? :rolleyes:
blessed6383
i have to disagree simes mine was dropped 60mm and i could out run scoobys on the back roads and my mates 300bhp pulsa gti-r on the back roads and roundabouts and that was 4wd, as for the lowering welshpug i did meant at the hub end but yer i was unsure mate as was a while ago i did the job 3~4 years ago lol
Batfink
The main problem with running that low is the lack of suspension travel at the rear. I cut down the bumpstops on mine which was ok, but maybe not the best...
Looked good though ;)
GLPoomobile
But there's a difference between 'handling' (which some might feel is a subjective topic) and having a car which sticks to the road well. A lot of modern cars can achieve higher cornering speeds than a 205 GTI due to the advances made in modern suspension, but that doesn't necessarily mean they 'handle' as well as a 205 GTI.
Having bigger bollocks will also enable you to take a corner at higher speeds than others :ph34r:
  • Haha 1
blessed6383
Looked good though :ph34r:
true it is a bit minimal but if your useing shortern damper its not too bad
