AlexB
Xs Tuning
AlexB
right guys
i have a 1989 1.4 205 xs rocking a carb
and a 1993 1.4 106 xsi motor in parts
are the internals the same in the 2 motors?
plan is all new shells ect in the xsi motor then clean/service my carb and drop it all in the car so no real time of the car not running
thing confusing me is the xs iirc is 80hp the xsi is 100hp
would i end up with a 100 hp xs??
im thinking the cams are different (xsi and 106 rallye run the big bearing cam iirc so its if the xs does) and i know the xsi has a raised compression ratio through crowned pistons (as its all apart)
if it does will my solex run the camshaft or is a set of twin 40s needed to get the best?
if im gunna end up going 40s i have a s1 106 rallye camshaft i might aswell fit like
swordfish210
  AlexB said:
right guys
No they're not, the XSI has domed pistons which add a bit of compression. However the XSI head has larger combustion chambers so the comperssion on the two engine is about the same, add XSI pistons to XS head and you will have a higher comperssion ratio.
Does it need them?
Not if you're running the crappy carb! The XSI uses multi-point injection so delivers the fuel much more efficiently. Also the plenum on the XSI can deliver more air than the solex carb and it works better with the larger ports on the XSI head.
Yes the cams are different, although i dont know the duration offhand. See above for compresson ratio.
Just put the whole XSI engne in and some Twin 40's would be my advice. Theres no point pissing about with the solex carb, it's small and crap.
AlexB
well the xsi motor is in bits as in pistons and rods out head off and stripped and allsorts
so basically id be best doing what i say at the end then from what your saying?
rebuild the xsi bottom end
rebuild the xsi head and lob the rallye cam in
and get some twin 40s
swordfish210
Yeah pretty much.
AlexB
sound then lol
just wanted to clear a few bits up before i started to think about comitting money to the engine like
so if that will all work like and is the best way thats what ill do
