Bottrill
Another Non Starter...
Bottrill
Parked the car up last Saturday (1.6 GTI) all running very nicely.
Left a week.
Came to start and it won't have it. The engine turns over, and you can hear it trying to start, it keeps firing for a split second every now and again.
In the last 500 miles the following related items were replaced. Leads, plugs, ignition module, TPS, fuel filter, injectors serviced, cap and rotor arm.
Eventually the battery died. I kept trying it on and off as I was convinced it was going to catch and splutter into life.
Put a new battery on, still nothing. Took dizzy off, cleaned up all contacts on cap and rotor arm, and put the hair dryer on the dizzy to dry out any moisture.
Have good fuel pressure
but a very weak spark... any thoughts. I can't seem to get my head round this... it was all going so well for the 500 miles since re-build.
Cheers.
Edited by Bottrill
splant
well my non starter after trying everything turned out to be the coil shorting { small cracks in it] i luckily saw sparks jumping from the coil to ground . try cranking it in the dark while looking under the bonnet for errant sparks
luggy
Clean the king lead male connection on the coil and the same on the dizzy with some sandpaper or emery cloth :) .
large
check your earth on the gearbox aswell.
DamirGTI
Check the dizzy signal cable :) the black one with 3pin yellow plug on the end ... this one provides initial/main triggering signal for both the ignition (ignition amp.) and fueling as well ..
Out of curiosity , which brand is this the replacement ignition amp. ?
Damir :lol:
Bottrill
Damir :lol:
I bought the gen Bosch part not an Intermotor one, Damir.
I changed the dizzy signal cable last week owith one off a spare dizzy I won on ebay as the old one had split. I was convinced I had snapped it inside the insulation during the re-build... nothing to say the new one could be sh@gged too I suppose.
Edited by Bottrill
DamirGTI
Righto , tried with another known good coil perhaps ? :)
Damir :lol:
EDIT : haven't said anything about fuel bar the fuel pressure , do you have fuel supply via all the 4 injectors @ cranking ?
Edited by DamirGTI
Bottrill
Damir :lol:
Ok, will get hold of another coil.
I slackened off the rubber hose at the fuel rail, cranked over, and pretty much filled a litre container. You can hear the fuel pump priming when you turn the ignition on. I assumed all was good here.
Cheers guys, much appreciated.
Bottrill
Knackered distributor. Cheers for your help guys.
