sam jfm
Spot Lamps
sam jfm
Any recommendations for rally spot lamps??
SPGTi
Stand alone or for a pod ?
Stand alone, these are probably the best.
lightforce
Craigb
I've used super oscars and hella 3000 , both good lamps
My pod has a pair of drives and a pair of Spots in the middle all hella 3000's
sam jfm
well i was thinking pod, can most lights be pod mounted?
Craigb
I can take the inserts ( the actual lamp) out of my spot light casing and put them in my pod if I needed to . Have neveer needed to yet though.
Why ar you thinking pod or spots . What events are you thinking about ?
sam jfm
northwest stages
Craigb
How many night stages ?
If there's alot of them go for a pod , (expensive but worth it ) if not just a pair of good spots a lot cheaper off ebay .
just my opinion .
Henry Yorke
Pods traditionally are required when you need a couple of long distance and a couple pointing to the sides (particularly if it is a night rally on gravel and you have rear wheel drive!). I would agree with Craigs advice.
