Bogsye
[engine_work] 1.9 8v Engine & Front End Refresh
10 hours ago, ladderboy said:
I'm also starting on a repair job for badly rusted rear of boot floor. These, "Boot repair panels which replace rear 250-300mm of floor", where do you get them from? Brian in Glasgow, did you get a floor CAD drawn and laser cut, and if so, could I get one?? Or were you referring to the subframe? Thanx!
I don't know where Brian got his panel from but they are available from Expressed steel panels.
g
Bogsye
Sorry for the slow response!
Yes, my repair panel for the bootfloor cam from Expressed Steel Panels as linked above by Graham.
The bit I need to get fabricated is the crossmember that sits underneath the floor and runs across the width. I've taken it off but need to get it drawn up and then laser cut and folded. Life has got in the way recently but hopefully I'll be back on this again soonish..
