Daviewonder
Vss Location
Daviewonder
Hello all,
Im in the middle of doing the wiring on my 2.0 turbo conversion from a 406, I have the bit of the Vehicle Speed Sensor that goes on the gearbox but I understand that theres another part to it thats located elsewhere?
1 Where is this other bit on the donor car?
2 What does this other bit look like?
3 The sensor on my gearbox has 2 wires connecting to it but most others Ive seen have 3, Whats the difference?
Ta
Edited by Daviewonder
pugpete1108
  Daviewonder said:
Hello all,
Im in the middle of doing the wiring on my 2.0 turbo conversion, I have the bit of the Vehicle Speed Sensor that goes on the gearbox but I understand that theres another part to it thats located elsewhere?
Ta
you mean the crank sensor? afaik there is only the one part-the actual sensor itself which goes direct to the ecu
mine has three wires - a signal, a ground and an earth shield.
not much help really, what donor car is it?
Daviewonder
No mate, this thing-
is there another bit of it located somewhere else that this bit connects to?
You need the 3 wire version AFAIK, Just wire it to the ECU and +ve feed nothing else unless you run a electronic speedo
Daviewonder
My loom only has a 2 pin connector so I guess its a simpler version? Ah I see the other bit is for driving the speedo but I dont need this as im using the speedo cable. Suddenly it also becomes so clear, Cheers Miles :)
ade 4wd
The speed interface box is located behind the glovebox in a 406. Its a small black plastic box with white plastic on one end where the electrical connector is. This interface box is only used with 2 pin speed sensors. As said before use a 3 pin speed sensor, much easier to wire up.
Daviewonder
Ok guys, one last check before I fry everything, so the 2 pin speed sensor goes to the module behind the glovebox then the module connects to pin 9 on the ecu (not that I have a module). The 3 pin speed sensor that I now intend to use fits like this- pin 1 goes to switched live, pin 2 goes to earth, pin 3 goes to pin 9 on ecu.
Does this sound right?
cheers, Dave.
ade 4wd
That is correct.
