vickiw106
4 Pot Calipers
vickiw106
After doing a rally the weekend if feel its time to upgrade my brakes
I am currently running 14 inch rims and wondered what options are open to me.
Any ideas or opinions would be appreciated
what spec are you running now?
vickiw106
i am currently running 206 1.6 16 valve calipers with 266mm discs.
i do have drums on the back but i going to swap for disc setup.
thanks
ian
what about the rest of the car?
wouldn't bother with discs at the back for rallying, handbrake is far better on drums.
budget is also important here, I service for a few 205 rally cars, the standard engined 1.6 runs standard 1.6 calipers with yellowstuff pads and race fluid, no issues at all :lol:
the other has Bremsport 28-something belled discs and 4 pot calipers, but are under 15" wheels, hawk black pads, race fluid and a pedal box.
another car is running standard 1.9 calipers and discs, not sure what pads he has, again, race fluid.
andychalmers
The only 4 pots Im aware of that fit under 14" wheels are Hi-spec ones (they will actually fit under 13"), they use a 285mm disk I think.
1600 & 1900 disk setup are fine for rally use as long as you use something like Mintex 1155 pads.
drums on the back are better than disks but are a pain to service every rally, disks are fine but crap handbrake so fit a long vertical one.
there's more than just Hi spec that'll fit under there, IIRC peugeot sport themselves had setup for the 106 made by AP, I know that Wilwoods definitely fit under a 106 14" steel.
Edited by welshpug
that's the buggers I had in mind!
another RR member has 270mm Wilwoods under standard rallye steel wheels.
GTI6BOY
the largest brake set up hi-spec can get under a rallye wheel is 260mm
that's amusing when a stock pug caliper uses a 266mm like they already have fitted, and that wilwoods and AP can take 10mm more! well 5mm..
kyepan
was gonna say ap would proably do something!
EdCherry
We've got AP Racing 4 pots under 13s at college.
yeah but how big are the discs ed ;)
EdCherry
pretty f***ing huge... centre lock wheel though on a floating bell...
Jer309GTi
Very slightly off-topic, but do 306 xsi 266mm brakes fit under a 106 rallye steel does anyone know?
sussex_gti
Yes, had them on my 106 xsi with Rallye steels. Were brilliant brakes.
Jer309GTi
Nathan_marriott
On my rally car ive got alcon 4 pots on 288ish (?? cant remember as its been while since ive used it been doing too many events in the MKII Escort!)
They fit under peugeot 14" wheels but they have to be the GTX ones as they have more clearance in the wheel. see pic. (just)
The Pug 106 AP ones fit under 14"s but think that they two have to be either Compomotive or GTX......
I would personally change to a different pad materiel and see how you get on.
I used to have 1.9 Calipers on my old car and worked well and they also didnt have those silly retaining plates that hold the pads in, that i used to wire lock in.......made a mess on my mates car when one came out.......
Use Mintex 1155 generally. On the 4 pots ive got DS3000 as they came with them and mintex 1155's as spare set. in the back ive got 1144's on discs.......
Edited by Nathan_marriott
vickiw106
thanks for everyones help
i think for cost reason i am going to stay with my setup but change
the pads
i am currently running mintex 1155's whats people opions on other types of pads
PaulJLLD
the pads
Try DS3000 know lots of people who use them on the front of 205s
