Guest mcalping
Rear Beam
Guest mcalping
I was talking to my Dad recently about my worn out squeaking rear beam and he mentioned something that he used to do with older cars and I was wondering if it would work. He is talking about drilling a hole in the beam and screwing in a grease nipple. Then packing the beam with grease. Any thoughts :D
jimistdt
I would think your best option is to get the beam stripped and you can see exactly what the damage it is. A disintegrated bearing or shaft wont benefit for long with the aid of a bit of grease.
I'm rebuilding mine this week, I chanced upon a good condition beam that I am re-furbing ready to do a straight swap.
Try a search, been covered before.
It's generally a good idea obviously, but it doesn't really stop the corrosion and wear, nowhere for the old grease to go, and there'll still be the condensation inside the beam...
SurGie
There'll still be the condensation inside the beam...
Hi Baz,
Just an idea but would drilling a hole or two in the middle of the beam with air vented plugs that only let
codensation out help stop condensation at all or cause more ?
I've stripped several beams that have been modified with grease nipples previously, and they've still suffered the same issues - the only thing it seems to prevent is the beam completely siezing, but it will still suffer bearing, shaft, and ultimately tube failure.
