swordfish210
266mm Calipers
swordfish210
I'm looking to upgrade the brakes on my XT so i've been looking at 266mm ones but i've heard there are a few different types of calipers so i was wondering is there any one that would have a significant benifit over the others. I'm watching these on egay, are they any good?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=220401684305
Thanks guys. Mark
I believe the 57mm piston ones from 307s are the better ones. (iirc!)
Edited by Baz
ifcho
I would avoid the 405 266mm calipers and the early 306 s16/xsi calipers. They are with much smaller pads.
The newer calipers, found on partners, berlingos, 306 XSI after 96 have larger cooling fins and larger pads.
Here is a pic of the newer calipesr which I am very satisfied with:
ran them for seven laps on a local track and even though the pads were normal road pads (TEXTArR) and with standard discs, I never had problems braking (after the race I found that the pads have turned white and the discs were blue..)
http://gallery.ifcho.net//cache_big/205GTI...es/STA50884.JPG
vickiw106
what about the ones of a 206 1.6 xsi they run 266 discs
does anyone now the piston size on those
They do, but from memory uprated pads are easily available and comparitively cheap compared to some of the other 266mm options
If you need some, I do have a set of 266mm calipers from a late 306 XSi 1.8 16v sat in the garage surplus to requirements.
swordfish210
I might take you up on those ant. Thanks for the advice guys.
d-9
206/307 266s are really good, ran them on my 106 for years.
swordfish210
Ok i bought those calipers from Anthony but i've got a few questions (i had a mind blank when i was at his place and forgot to ask him)
1. Can i get a set of caliper bolts from Peugeot?
2. What sort of track pads are available for them?
3. Will the standard master cylinder be fine for them (they're a 54mm piston)
Thanks in advance. Mark
I probably have a set of bolts for them if needed Mark - they're just the same as 1.9 and other Girling/Lucas bolts, so easily available.
Standard GTi (20.6mm) MC will be fine, but there will be slightly more pedal travel than currently. 22mm MC would probably be perfect I'd imagine if you can find a suitable one.
Not sure about the pad choice for them, as I never looked into it that far - almost certainly be able to get the usual candidates like EBC Greenstuff, Mintex 1144 and Ferodo DS2500, but not sure about anything more hardcore than that. Worth having a browse through the online catalogs of the normal brake companies and seeing what you can find - I know there's a good choice for the earlier XSi calipers, but not sure about the later style that you've got.
swordfish210
Thanks mate, i'll have a browse around, not sure i can be bothered to go all the way back to yours just for a set of bolts :lol:
EdCherry
if it comes to it when I eventually get round to picking up these wheels I can get the bolts for you mark.
I needed some caliper bolts so I just popped down the scrappy and raided a diesel 306 of some description, sorted.
gti_al
Do 405 calipers bolt onto 205 hubs? I thought i tried one and it wasn't going to work, but i can't remember why now.
That would be convenient if they did
swordfish210
Well i had a hunt around for some pads today and all i could find were some Mintex 1144's but they were on a 6 week made to order list so i just bought some cheap and cheerful Ferrodo pads for the time being, and some budget discs.
swordfish210
I've got it all fitted now. I ended up using:
Ph2 306 XSI 1.8 16v Lucas Calipers
Brake Parts discs
Ferrodo Premier pads (for a Citroen Berlingo ;) )
405 1.8 Master Cylinder (22.2mm)
ATE Super Blue Racing DOT4 brake fluid
Goodridge Hoses
Willwood bias valve
I'm only using 3 ports on the MC and the pedal travel is just about perfect, exactly right for heel toe braking and it had loads of feel. I'm really happy with the way it has turned out and i can't wait to see what it's like on track. I'll get some decent pads in there (and maybe some of Rippthrough's lightweight discs :lol: ) sometime next year but to be honest it pulls up really well as it is and i havent even fully bedded in the pads yet.
Glad you're happy with the results Mark ;)
