Fearon
Engine Problems..
Fearon
Just picked up a 205 GTi, phase 2, 1.6....
Got a lil niggle..
Takes a while to start on the key, when cold.....
I would say atleast 5 seconds, then kinda struggles, so you have to help rev her up...
Then, she will stall..
It will start back up fine, but for a few moments, you have to idle it....
Im thinking this is a common problem... But how can i cure this niggle..
DamirGTI
Sounds like SAD (choke) problem :) which is common malfunction ..
Search button will reveal loads of threads regarding this subject :lol: but for the beginning , start up the engine from stone cold and try squeezing the SAD pipe in order to check if it's working (if it works the engine will stall a bit when you squeeze the pipe) and look around the SAD pipework if you can find loosen clip or perished air pipe .
Damir :P
Fearon
Cheers, just cleaned all the TB, and now ideling 500rpm to high....
Dunno abt this SAD thing, but will search!
Simes
I've got an SAD kicking around if you're interested.
Have a read first on all the known issues - it's quite a common thing on the old 8v.
davey205
this was my old car and my new one does the same i wish i could get it sorted its so embarrising simes i am interested if fearon isn't in the sad
Edited by davey205
Fearon
How much fort the sad...
Davey if you want it you can have it
Ive now got the ideling sorted!
davey205
wicked what did u do to get it sorted?
