jonand
Gti6 Piston Sizes
jonand
Can anyone tell me if there are oversize pistons available for the GTI6 (other than aftermarket forged ones). I recently bought a block and pistons off the forum, and found one of the pistons was damaged. When trying to obtain a replacement - I was having difficulty in matching the numbers etched into the piston face. I then measured the piston diameter and found it to be 86.35mm, although it looks identical to 'std' GTI6 pistons ffrom what I've seen on here. I further confirmed that the pistons will not fit into a worn S16 block I had knocking about.
Any Ideas ?
Thanks Jon
they may well be marked "A", "B" or "C", don't know what tolerances gti6 engines are specified to, but I doubt they are factory standard sizes as they tend to be under the nominal bore diameter.
brumster
The parts catalogue lists two 'repar' options, which I'd relate to oversize - 0628G7 and 0628G8 - maybe a call to a friendly Pug parts dealer can give you the details of their sizing?
jonand
Thanks Guys.
Having no luck with the XU10J4RS 'repair' sizes, although the similar 'repair' sizes for the XU10J4R are +0.25, and +0.60 apparently (thanks Welshpug). My ones do indeed have a +0.6 inscribed on the top face, so looks like a trend emerging here - anyone got a +0.6 piston to spare :D
