Peetypug
Mi16 Running On 3 Cylinders
Peetypug
well i picked my le mans up on wednesday and today has been the first day i've had chance to look at it
its was running on 3 cylinders and i dont know why
i've changed the plugs, the coilpacks and the coilpack loom (took them off my running mi16) and its still the same
calvinhorse has sugested the ignition amp
anything else?
Compression test it.
Have you determined which cyl is not firing? What does the plug from this cyl look like?
Peetypug
well
the plug in the cylider nearest to the drivers side (we'll call that number 4) was clean, the others were covered in carbon
so i cleaned them all and put them back in
this time cylinder 1 was missing. so i took it that this may have been the plug that was in cyl 4
so i swapped them for 4 new plugs and there was no difference
thats when i swapped the coil packs and it was the same again
BackStreetRacecars
compresion test and/or leakdown test....
so you can make sure its ignition faults or fueling rather than engine problems!
Is the injector firing/working?
Sparking from all four plugs?
Peetypug
all 4 are coilpacks are firing.
As for the injectors firing i dont know.
They do look like new injectors though
Peetypug
i've been searching and all thats coming up is problems with the alloy block engine
its all dizzy caps and leads ;)
tomorrow i'm gona
compression test it
take the plugs, coils and coil loom off my runner and try them
then the ignition amp
could it be an ecu problem? i dont think it could be with the problem changing cylinders
other than that i'm stumped :)
Peetypug
well i spent the morning trying to get it to run properly without any success :wub:
I put some fuel into it as it must have been very low and guess what?
Thats right, it was the fuel causing it to run like crap!
I think it was old stuff.
doh! if its road legal its worth getting it nice and warm and then changing the oil if its been sat for some time.
Peetypug
i've driven it a few miles round the area since and its great,
I'm gona check it over then mot it.
mr_exe
Have you checked the ACAV vacuum intake thingy? When they play up they run badly
Peetypug
i dont know what that is, but i changed as much as i could, then put all the original parts it started with back on.
Then put some new petrol in and it was sweet as a nut.
Henry Yorke
Don't forget to log your Le Mans here if you haven't already (Le Mans Register)
Peetypug
i think its already on there.
It was owned by a psooc member
