CRM
Pas Conversion On A 1.4 Tu
CRM
Hi all, has anyone done a conversion to make the steering lighter.
Its a 92 1.4 SPFI and am i best looking for oe PAS equipment and rack from a non GTI (if so which model) or an electric rack from one of other cars ?
Advice and rough costs would be helpfull
brolly
any body has any information as i'm trying to do the same thing
Peetypug
i'd go for the pump and engine brackets off a 306 tu engine
then the pipes, rack and resevior from a 205 gti
GTI6BOY
Tu engines are sooooo light it feels like its got power steering anyway?
Think you need some are muscules :rolleyes:
bouver
None of my cars have power steering. You get a couple more bhp out of the engine, and exercise is good for you!
brolly
errrrmmm i don't need any more muscles , i want to PAS my 205 just for the comfort of it not because its too hard to turn the steering :rolleyes:
Edited by brolly
AdamP
I've been fitting a PAS rack to the RG today and come across a couple of issues:
1) the fatter pinion assembly doesnt clear the gear linkage post, so I had to cut a notch out of the post
2) the linkage wants to go straight through a bracket on the rack to that had to be cut off
And i'm not running the power steering so I don't know how clearances go with the pipes, but i can see it being close!
AdamP
Once the gear quadrant goes on there's no way the pipes will go in.
brolly
any updates adam ?
AdamP
If you turn your head at a funny angle this photo shows the problem with the quadrant:
Dariooo
helo
I have a 205 RG 1.4i and I would put a power sterring, but I have a problem. I can't find a power sterring rack, pump, pipes.... for a 1.4 TU engine. It's possible to instal on this engine and on subframe (because a subframe is diferent from gti right?) power sterring from gti? I doubt.
Thank you
DaveW
How does eletric pas work?
Dariooo
on standar or mechanic pump you have a belt which rotate a pump...on eletric it's a electric motor wich rotate a pump and it take less power from engine as standar pump.
Another good propertis od electric it's that you can put it anywhere arount the engine because it needn't a belt.
