NeilGTi85
306 Xsi Switched Live ?
NeilGTi85
Just trying to connect an amp on my 306 XSi phase 3 and cant find the switched live.....anyone know which one it is:
I'm sure this is the power -
And these are the speakers? -
Cheers,
Neil
platty
Cr@p, cr@p and cr@p.....I completely forgot about today Neil :)
When are you about next? I can come down any point during the week, but the weekends a no no as I'm working.
Edit: re the problem.....buy yourself a multimeter you Miser :lol:
Edited by platty
NeilGTi85
:) Multi Meter...whats one of those :o I've got a screwdriver with a light on the end!!
By trial and error I found it was the white one in the top pic B)
I work mon-fri (Well sort off when im not on here)
I'll have to take a day off during the week. I'll let you know :(
Neil
platty
Hmm, just re-read my post....This weekend is a no no, following is fine, or as said, any point during this week.
Are you fitting an Amp to the factory headunit, hence the need for a switched live?
NeilGTi85
It was my sony head-unit from the 205....the cars original loom plugs stright into the back, no need for a harness?!
"Hmm, just re-read my post....This weekend is a no no, following is fine, or as said, any point during this week" Following sounds good to me, gives me some time to sort bits out.
You "might" want to bring along your multi-meter just incase magical volts strangley appear agian <_<
Neil :D
DaveW
2nd pic is the speakers, i think the think white wire is the live
NeilGTi85
Found out the the Pink wire (Top Pic) is the permanent Live and the white is the switched live.
