Front Bump Stop
In the middle of fitting my new SBC struts. Have got the original Pug strut off. The piston on the new SBC strut is a lot bigger and so the original bump stop will not fit it.
Do I need a bump stop on these new ones?
Are the bump stops internal or something?
I can't see how they'd fit, and the new SBC kit didn't have any bump stops with it, so I presume they are not needed.
Can anyone confirm before I fvck it up?!
tried phoning SBC?
Toddy
Bumpstop is internal
Super Josh
These are Bilstein 'inverted' dampers, and as Toddy said, the bumpstop is built into the lower part of the damper :)
I have just swapped my standard suspension and put the SBC kit back, has made a hell of a difference :)
Josh
Cheers all. Nearly done now :D
