EdCherry
Master Switch
EdCherry
Ok right,
Got the master switch and going to attempt wiring it in :blush: dangerous for me I know. All of the wire numbers are as refered to in haynes workshop manual on page 368.
Basically I've established that on the relay, the resistor spade is going to be earthed to the bulkhead or the steering column support.
Now the main electrical feed circuit spade, do I just bridge from the nut where the alternator and starter cabling goes in with a 20amp wire?
Ignition coil spade, got 3 wires to choose from according to haynes, wire's 2, 112 and 112a. Do I just splice into one of these wires and onto the relay? and which one? 20amp wire again will do?
Ignition switch spade, same as above really do I just splice into the existing loom, wires +AA, +AC and +D? 20amp wire again?
Also instead of taking a cable all the way back from the connector in the engine bay that goes onto the battery for the main loom, can I just splice into wire 1/1a which enters the fusebox at 706.
Thanks very much ed.
Edited by EdCherry
Didn't the master switch come with a wiring guide? If not I think the PTS Rallybuild book might cover fitting one which you can download from the members area on PSOOC forum.
112 & 112a are part of the rev counter wiring so I doubt you'll need to run them through the master switch.
Wire #2 is the ignition switched live for the coil etc so you could use that but wire 1/1A direct from the battery is probably the better choice imo because that will cut all power to the car electrically.
Not sure what guage of wire you'd need but I'd use at least the same size core as whats fitted to the fusebox etc now minimum.
Spiky
on my FIA kill swich, and i assume thats what we talking about
ericdean
I've got one of these on order for the track toy, the wire that pugtorque mentions above, is this the brown cable from the distribution block near the pass side headlight?
Also, is there a way of removing the immoboliser function from next to the steering column?
Eric
philfingers
you don't need bother with the resistor. It's basically there to load the alternator when it's been cut off but as all the other electrical circuits are presnt in the car, fuel pump, ecu etc then this circuits will use the power in the few secs the motor takes to stop spinning. chances are if you've pulled the master switch you'll have your foot on the brakes too!
Yes, thats the wire I mean.
Standard 205 GTI's really never had a factory immobiliser so any you have will be fitted as an aftermarket alarm / immobiliser & you should be able to remove it quite easily if you do it one wire at a time but it might be worth looking how it has been wired in first because if its just spliced intot he igntion barrel wires then a different ignition barrel will remove it completely.
Exactly the confirmation I was looking for for a Saxo as it happens, it has 2 distribution boxes next to the battery, one with hefty fuses for I think ABS and PAS, the other fr the rest of the car.
Do I wire one to spade 1 and the other to spade 2?
ericdean
Thanks for that Graham.
The immobilser (I'm assuming that's what it is!!) is a little pen shaped 'doofer' that when offered upto a little metal dot allows the ignition circuitry to energise, I've not had the panel off to check the wiring yet tho, it may all come clear then!!
Eric
blandy
Bringing back a old thread.
With the switch for the bottom pins on the diagram marked 2. Which wire are people cutting into? I'm guessing a wire is chopped and then one end fitted to one terminal and the other to the 2nd terminal so the wire now runs through the switch?
unariciflocos
Switched live I guess, red one in one of the multi plugs iirc
blandy
Just reading on gti6 forum that some people cut into the thick wires from the ignition switch? Is this necessary or can it be cut into somewhere else like the multiplugs as suggested? Attempting to have a go today and then my dash can finally go back in
To isolate the engine all you need is the switched positive wire to be cut along with the main battery one of course, Pointless cutting into the ignition wires as it just add's to the 205's famous starting issues
