pip470 61 Posted December 29, 2006 Hi I am planning on fitting my new bucket seats to two welded bars to the floor as many have done before but what I cant find out is how you remove the old seat mounts that are spot welded. I thought you just drilled where the divet left from the weld was but now i have a couple of holes in my floor. Any advice would be greatfull. Cheers Phill Share this post Link to post Share on other sites
welshpug 1,622 Posted December 29, 2006 thats the only way, drill them, fill the hole with a plug of weld. Share this post Link to post Share on other sites
Paintguy 0 Posted December 29, 2006 (edited) Use a proper spot weld drill! They look similar to a normal drill bit, but the head is much flatter, with a centralising point, which makes it much easier to drill through just one skin. You can also get ones like this which have a spring loaded central pin, and have some form of depth control. Where there is access, I use a tool like this: It use bits like the ones pictured above, but allows very fine depth adjustment so you never go through the underlying panel(s). Edited for spelling.... Edited December 29, 2006 by Paintguy Share this post Link to post Share on other sites
