ryan13961345402285
Ecu Code 54
ryan13961345402285
Hi again guys.
I got the knock sensor issue sorted out, but fault code 54 is now appearing which is a problem with the ECU afaik.
If this code is up does the ECU revert to a default "get you home" map? The car is a tad sluggish and not very easy on petrol. If I clear the code it reappears after about a minute of driving. This code probably covers a range of ECU faults, but are there any faults in particular that are more common?
I've checked all the usual things; ie water ingress, loose wiring and all seems to be in order. I would change the relay to see if it helps but I'm not sure which one it is
The ECU is a 355 and I've got no hope of finding one over here to test it against.
Ryan
