Ahl
Wheel Bearing Information
jimmi
Cheers men - as I thought - just making sure !
jimmi
what is the correct torque-ing up procedure /torque figures when fitting new 1.9 axle pins and new bearings ? Is it ok to torque up with new bearing in situ to pull the pin fully home or should pin be tightened fully home before bearing is fitted ?
I press them in, but if you are pulling them in by the threads it's probably wise to pull the stub axle home with a bit of tube and a nut and then fit the bearing.
jimmi
Tom the arms are still on beam on car so will I pull pins in using spacer /drift once I remove them from the freezer. I recall reading somewhere to torque bearing up to 200 + lb/ft the slacken and re-torque to 160 lb/ft is that correct ?
I'll be honest and say no idea. I do them up FT with a big bar and/or rattle them up solid with the gun and always have done. Never had an issue doing so, although I'm sure there will be a proper torque setting somewhere in the Haynes book.
jimmi
I'll be doing same - airgun and a big bar
Ozymandis
This
I once stripped one trying to pull it in against a new bearing, only a little of the threads available at first and its not enough.
Motorsport Artist
I'm just fitting new rear hubs to my project car. The correct torque setting for the rear hub according to the Haynes manual is 159 Ibf ft or 215 Nm. This seems a lot of pressure on the rubber seal on the back of the hub and I wonder if the hub would turn freely. Can anyone confirm this torque setting is correct for a disc braked rear axle please. Thanks
sounds about right, the seal wont be touching anything other than the bearing itself.
a new bearing will be fairly tight, what with friction from a new seal and fresh grease.
Motorsport Artist
Has anyone got any pics of what the whole hub assembly onto the stub axle should look like. I've fitted new hubs from Pug1Off but as soon as I start to tighten the hub nut the hub stops rotating. I can't imagine getting anywhere near 159 Ibf ft and am wondering if I've done something wrong? I can't find anything on the forum to help really. Thanks folks. Fran
jimmi
Did you replace the pins/axles ? .... If so, are fully home in the arms and if you've disc brakes the pins should be approx 132mm in length overall ? Drum Brake pins are shorter. Lastly, If you have'nt replaced the pins - have you checked that the pins/axles are not bent ?
Sequence of parts when fitting is: Rear bearing seal disc ( mates up against rubber seal at rear of hub), then bearing/hub assembly (which should slide onto the pin sufficiently to leave threads visible ) , then the washer, then the nut.
Motorsport Artist
Thanks for the response Jim. I discovered that I had put the metal collar on the stub axle (the one straight after the back plate) the wrong way round. SImple things eh! Correcting this enabled me to torque up the hubs correctly and easily with the hubs still spinning freely. The trailing arms are new with machined faces for 3 degrees of camber so I'm now onto fitting my new thicker torsion bars thanks to Pug1Off who continue to be mega helpful with my build and have just built my new 240bhp GTI 6 engine. I'm really grateful for all of the advice from people on this excellent forum so thank you again. Fran
retroriley
SKF VKBA1405 (for a Non ABS 1.9 GTi) can be bought from Amazon.co.uk
When I looked this morning they were available at £74.19 each delivered but this could change as I just ordered two.
There's a 2 - 5 week waiting list but that was the case when I last ordered this part from Amazon.
that's rather expensive, probably three times as much as I'd be willing to spend!
Carparts4less list SNR at £28.
allanallen
Have to agree that's a bit dear! Im yet to have a bad report on the BRT boxed 'Korea' bearings at £24+vat.
