gerlewislewis
Rear Brakes Scrubbing
gerlewislewis
I recently changed the rear discs for an MOT, but not the pads.
Everything has been fine for 5 months, then SUDDENLY its scrubbing really badly, almost sounds like a coke can or something is stuck in the caliper!
Is this likely to be cos I didnt change the pads at the same time? and if so, do you think changing the pads now will solve my problem?
The expensive thing to do would be to change the pads and discs (again!), but id like to avoid that if at all poss!
Ger
I'd check that you still have pads left :)
Check that one of the pads hasn't fallen out - you'd not be the first person that's happened to after recently working on the rear brakes
gerlewislewis
good point. i will check them this morning
gerlewislewis
ok,its definatly the near side wheel as Ive just noticed the tyre has gone orange form all the metal shards! also the wheel smells of iron!
Both pads are in place, but the back of the disc looks all shiney/scratched.
Im not sure if this is because all the tread has gone, or if its cos I didnt change the pads.
I will need to take the wheel of and have a proper look.
Ger
gerlewislewis
update: just took off the wheel, and the pad has sheard off its mounting.
so I defo need a new pad. But do I need to change the disc also....?
Ger
gerlewislewis
well ive changed the pad. but the disc might just tear it up, I will have to watch this space!
Ger
