sideways danny 0 Posted October 1, 2008 Hi, I've had a good search about and anything that comes up in the search leads to old/dead links. I really need a pinout for the standard ECU. I'm fitting an SMT6. Any help much appreciated Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted October 1, 2008 I've posted this before but I couldn't find it in a search for the topic by whom I thought I'd replied with them to. Anyway, only one side of the ecu plug on the 1.6 or 1.9 Jetronic ecu plug is connected in the order below; Pin 1 = ignition coil. Pin 2 = Throttle switch. Pin 3 = Throttle switch. Pin 4 = Ignition switch start signal. Pin 5 = earth. Pin 6 = not connected. Pin 7 = Air Flow meter. Pin 8 = Intake air temp sensor (in AFM). Pin 9 = Relay module (tachymetric relay middle pin). Pin 10 = Engine coolant temp sender (CTS). Pin 11 = not connected. Pin 12 = Injectors. Pin 13 = Earth. Pin 14 - 25 = not connected. Graham. 1 Share this post Link to post Share on other sites
sideways danny 0 Posted October 3, 2008 Fantastic!!!! thanks for your help Share this post Link to post Share on other sites
sideways danny 0 Posted October 5, 2008 right, had some fun with this yesterday. No SMT6 wiring diagrams available for the 205, but the nova GTE uses a very similar injection system so i did some backwards engineering and got it hooked up. Just had trouble with de-coding the firing pattern/rpm signal. Does anyone know any more about what the rpm output into the standard ECU is? the SMT is fully configurable but i can't fathom it Share this post Link to post Share on other sites
pug_ham 240 3 Cars Posted October 5, 2008 The standard Jetronic ecu doesn't have any rpm output afaik, it simply supplies fuelling. All the sparking is controlled by the dizzy & the rev counter gets its signal from the coil. Graham. Share this post Link to post Share on other sites
welshpug 1,621 Posted October 5, 2008 wire 112J goes from the coil to Pin1 of the ECU, would that be the RPM signal you were after? Share this post Link to post Share on other sites
sideways danny 0 Posted October 6, 2008 wire 112J goes from the coil to Pin1 of the ECU, would that be the RPM signal you were after? yes that's the one. I need to know how the RPM signal is constructed though. There's a pulse there, I can see it on the graphical display in the piggyback software when I'm cranking the starter. Share this post Link to post Share on other sites
sideways danny 0 Posted October 6, 2008 The standard Jetronic ecu doesn't have any rpm output afaik, it simply supplies fuelling. All the sparking is controlled by the dizzy & the rev counter gets its signal from the coil. Graham. there has to be an RPM feedback from the engine to the ECU no matter how basic the system is, the injectors fire twice every cycle (in batch fire sequence), and the ecu fires them so it has to be decoding an rpm signal . I know the jetronic only controls fueling, but it still needs to know engine speed in some form. Share this post Link to post Share on other sites
welshpug 1,621 Posted October 6, 2008 The signal is identical to the one the tacho gets, i.e a pulse of some sort on every spark. Share this post Link to post Share on other sites
Tom Fenton 1,524 Posted October 6, 2008 What is this piggyback ECU supposed to do? I don't see how you will gain anything from fitting such a thing to a 205? Share this post Link to post Share on other sites
welshpug 1,621 Posted October 6, 2008 from a google search for SMT6 it seems you would be able to use it as a 5th injector controler, or to replace the MAF sensor with a MAP. price is around $500 US. Share this post Link to post Share on other sites
sideways danny 0 Posted October 6, 2008 going to remap the fueling to match the work i've done to the engine (head porting, matched inlet manifold, exhaust and air filter. So far all the mods I've done have cost me £0 (including the SMT which is a second hand unit we had at work) this car's an exercise in major cheap-skate-ness, I'm saving the proper modifications for my 1.9 Share this post Link to post Share on other sites
