Dandu 0 Posted August 7, 2007 Hi, I'd like to know if there is a common orientation for setting up the air/fuel-ratio. In my view I'm in need to achieve the following: 1. Idle: Lambda 1 2. Partial Throttle: Lamdba 0,96 (constantly at 3000rpm, 4000rpm f.e.) 3. Wide Open Throttle: Lambda 0,86. Much thanks in advance. Cheers Dandu Share this post Link to post Share on other sites
petert 617 Posted August 7, 2007 Hi, I'd like to know if there is a common orientation for setting up the air/fuel-ratio. In my view I'm in need to achieve the following: 1. Idle: Lambda 1 2. Partial Throttle: Lamdba 0,96 (constantly at 3000rpm, 4000rpm f.e.) 3. Wide Open Throttle: Lambda 0,86. Much thanks in advance. Cheers Dandu I can't recall exactly how the lambda values match up with AFR, but it should be more like this: 1. Idle - 12.5 - 13:1 2. Part throttle, cruising - 14.7:1 (lamda 1) 3. Moderate loads around 13.5:1 4. Full Load, WOT - 12.7 - 13.0 (lamda 0.9?) Share this post Link to post Share on other sites
Dandu 0 Posted August 8, 2007 Much thanks Peter. I'm going to find a compromise. Bye Dandu Share this post Link to post Share on other sites
