FinalD 0 Posted July 3, 2007 (edited) My XR has some strange suspension problems. If I put any weight in the back (be it people, stuff in the boot etc.) the car drops like 3inches at the rear, and then with more weight, drops lower. My brother said something about it having 306 rear suspension or shocks, I do't know if 306 shocks are softer than 205 stock ones, but it really does drop, and it also makes what can only be described as a griding noise when going round corners (with weight, just me no noise). Anybody know what the problem actually is...it appears to mostly be from the rear passengerside...but then that is normally the side htat people are on, because I won't get out for them to get i nthe back I'm sure it is just the one corner of the car, so yeah, any help as to something to sort? It doesn't seem to affect performance (car still loves corners, twisties and speed ) -=EDIT=- Wrong part of the forums ...can it be moved to suspension etc. ? Cheers. Cheers. Rob Edited July 3, 2007 by FinalD Share this post Link to post Share on other sites
Jrod 7 Posted July 3, 2007 Probably lost a bumpstop. Share this post Link to post Share on other sites
DaveW 6 Posted July 3, 2007 Its just got soft suspension set up, i bet it dont even have a anti roll bar and some shagged shocks. Share this post Link to post Share on other sites
Sandy 189 Posted July 4, 2007 Dampers (correct name for "Shocks" ) don't affect the height, the springs do that. It sounds like a possible trailing arm bearing collapse though. Share this post Link to post Share on other sites
