djinuk
Mileage Not Moving
djinuk
In my 205 xs the clocks all work , alll light up, rev counter etc all works for the mileage never moves, its been like this for 8 months now since we brought the car , any ideas what could be up with it, is there any wires i should be checking or will it just need a new set of clock to go in ?
sonofsam
The mileage counter on the speedo clocks of a GTI is mechanical counter and is moved by the speedo cable.
You could always put in just the speedo head. See picture
(probably not the best example to show :P Item not in use :D
You would have to partialy disect the clocks and remove the needle to remove it,
So if your'e feeling lazy, you could just try a different set of clocks :D
Sam.
djinuk
diffrent set of clock sounds best bet, how do i set the mileage to correct figure ?
DaveW
erm you cant really try to find one with nearish the same mileage, unless you want to sit there all day with a drill!
t16ryan
you can change the mileage easily if you seperate the cogs
djinuk
hmm, could be a mission to find the correct clocks surely, mite have to attempt to adjust em
djinuk
if i say got a set of low low mileage clocks, would i need to let anybody know, as the engine has had a rebuild so i guess thats kinda a reason to , tehres a set on ebay at 33k :)
Casanova
Check the speedo cable - it is probably not properly in at one end.
djinuk
checked it and changed it and my speedo is fine soo not sure
