Dream Weaver
Battery Negative Terminal
Dream Weaver
Has anyone got rid of the twisty terminal on the battery negative and replaced it with a normal clamp?
My twisty thread is buggered and the earth lead won't stay attached to the battery, so I fancy buying a new clamp off Ebay and using that - just a normal clamp, with a hole for the wire to go which is then bolted down.
i.e. http://cgi.ebay.co.uk/2-X-BATTERY-TERMINAL...1QQcmdZViewItem
Just wondered if its OK using these instead of the std item?
Richie-Van-GTi
exactly what I have on mine :)
steve@cornwall
And mine
Jrod
and mine (but mines in the boot. :))
hengti
as an interim you can fix by replacing the plastic spinner with a nut; remove spinner by smashing it with a hammer (any excuse!), bend the lugs on the retaining washer back, refit using a nut.
not pretty but serves a purpose
Dream Weaver
hen, just realised that when looking at it this morning - nice quick fix so I can test out my latest mods :)
I will go for the clamps though when they arrive.
fencer
i found a clamp very similar (almost identical) to the original one. All I had to do is flatten out the parts which held the twisty thing in place.
i'll post a pic tonight if i remember
I've replaced the twist lock on all of my 205's, cheaper than that from the local motor factors & no waiting for the postie to deliver them.
Graham.
Dream Weaver
But that means going out of the house, and with little Ed in tow that's a big deal these days :blush:
Got one for £2 odd delivered off eBay, just await its arrival.
Just one thing - how does one cut the existing wires and bolt them into the new terminal? Anything I need to bear in mind?
Edited by Dream Weaver
Casanova
Yep, I replaced the useless original connectors with clamps too. Pretty self-explanatory to fit - just strip back an inch or so of cable and bolt it in. Job's a good un.
Edited by Casanova
Paintguy
I went for the bling option, but then I do have rather larger wiring than the average 205 :ph34r:
fencer
paintguy, the link to the image is dead.
Paintguy
The whole gallery seems to be down atm :) I'll see if I can host it somewhere else :(
