matt-k 0 Posted April 14, 2007 Hi, Ive finally got everything together to build up the engine but i cannot find the torque settings for the bottom end ive had a quick look on here and only found the top end settings, i have a haynes manual for the 405s but they dont seem to be in that either and i dont want to pay out for another just for torque settings! If anyone can help i would very much appreciate it as i wanted to get started tomorrow. The engine's an alloy XU9 mi16. Thanks, matt. Share this post Link to post Share on other sites
Mikey G 3 Posted April 14, 2007 Haynes shows the same settings for all XU engines as they all use similar components. Main bearings 40lb/ft, centre side bolts 18 lb/ft Big end bearings, stage 1 30 lb/ft fully slacken all nuts and retighten to stage 2, 15 lb/ft Stage 3 tighten through 70 degrees. HTH Share this post Link to post Share on other sites
WildCards 0 Posted May 24, 2007 Mikey G said: Haynes shows the same settings for all XU engines as they all use similar components. Main bearings 40lb/ft, centre side bolts 18 lb/ft Big end bearings, stage 1 30 lb/ft fully slacken all nuts and retighten to stage 2, 15 lb/ft Stage 3 tighten through 70 degrees. HTH Can any confirm this? I need to torque mine up tonight and the Haynes I bought off ebay hasn't arrived yet, although I do have one for a 205. Confirmation from a few bods would ease my mind. Share this post Link to post Share on other sites
Mikey G 3 Posted May 24, 2007 It was taken from a 405 Haynes manual and it didnt show any different torque settings for the bottom end between 8v and 16v engines. Share this post Link to post Share on other sites
WildCards 0 Posted May 24, 2007 Mikey G said: It was taken from a 405 Haynes manual and it didnt show any different torque settings for the bottom end between 8v and 16v engines. Nice one Share this post Link to post Share on other sites
