Rob Thomson
Motronic Or Jetronic?
Rob Thomson
Going to look at a 1992 (J) 205 tomorrow. Would it be running Jetronic or Motronic EFi? How can I tell?
Thanks.
Matt Holley
Most probably jetronic mine is a 92 J plate an was jetronic , but if its a cat one I think they are motronic
Jer309GTi
Take a look at the ECU code, on the sticker on the ECU. Theres a list somewhere on the interweb that tells you which ECU goes with which ignition system
probably easier to look at the air flow meter code, if it ends in 202 its motronic, if it doesnt its jetronic.
28CRAIG
Dont the metronic have a crank sensor?
Jer309GTi
Mine did, in the top of the gearbox
Rob Thomson
Thanks!
Emmy Seize
Vacuum advance on the distributor - easiest way to tell.
Motronics don´t have them.
