Gohn
LUCAS / BOSCH INJECTION PUMP PULLEYS INTERCHANGEABLE ?
Gohn
In the process of swapping over from my little LUCAS Diesel Injection Pump to a BOSCH
Got my Bosch pump but it came without the pulley, errr
Obviously I already have a pump pulley on the Lucas, but are they interchangeable ?? I've heard both yes and no..
Both Lucas/Bosch pulleys have 42 teeth
The peug part catalog lists different pulley part numbers:
Bosch: XUD7 , XUD7TD, XUD9 Bosch - #193028
XUD9TD Bosch - #193029
Lucas: all XUD/TD same #193020
If anyone's done it back when you had a diesel and can confirm either way, that would be much appreciated
xstian
I'm not sure if they are interchangeable, but I may have a spare bosch pulley if you need one.
Gohn
did a bit more looking
the different part numbers suggests they aren't interchangeable but its not conclusive
anyway, found a vid online by a guy that did a Lucas to Bosch changeover
and he actually compares the two pulleys but fails to mention which is which
I took a screenshot, the Bosch is on the right , its not larger just closer to the camera
thanks christian892795456_ScreenShot2023-03-28at3_04_15PM.thumb.png.0855b0845b0cc795378867d833255645.png I'll send you a message
Gohn
oh yeah, forgot - they are NOT interchangeable
the timing is slightly off one to the other
xstian
Hi Andrew,
The one I have is on the left and it defiantly came off a Bosch pump. I think you have them the wrong way round in the above photo. This is a link to a Bosch pump fitted with the same pulley as I have.
https://www.proxyparts.com/car-parts-stock/information/make/peugeot/model/306/part/mechanical-fuel-pump/partid/88930/
I hadn't noticed you where in Australia, but you are welcome to it. Do you know what code your pump is, some have smaller internals?
Edited by xstian
Gohn
yeah saw that pump in the link
I've two Lucas pulleys and both look like the one on the left, and same as in your link
so maybe you just can't tell from looking at them ?
u could post it to a UK address , is it from a XUD9TD or non turbo ?
xstian
It's from a turbo, I'll check this morning that it fits a bosch pump.
Gohn
cheers xstian
but both pulleys will fit on either pump
both pulley keyways, centre taper and timing holes are the same
the lucas pulley is the one with the 6 round cutouts
also, the bosch pulley the outer face is recessed and the inner (closest to pump) is almost flush
xstian
Hi Andy,
I had a look this morning. I have both versions of the pulley and indeed you are right, although they look different they both have the same timing marks and key way location. Which one do you want? The Bosch pulley (on the right in your photo) is much lighter.
Not that it makes any difference, but the 3 Bosch pumps I have here all the the pulley with the 6 round holes fitted and the only Lucas pump I have has the star type pulley fitted.
Gohn
really !! its getting worse, I knew it'd be like this if the pump came without a pulley
the pulleys pictured above were both non-turbo. Lucas left, Bosch right
if you have pics of yours with exactly what pump Bosch/Lucas D/TD that may help
Gohn
The one that's on the Bosch TurboD pump
thanks christian, I'll message the address
Jimarilo
On 3/28/2023 at 4:10 PM, xstian said:
Hi Andrew,
Hi do you still have a spare pulley for a bosch diesel injector pump ??? I am looking for one to buy ........cheers
xstian
Hi, sorry for the late reply. I should still have it if you are interested.
Christian.
Jimarilo
Hi, thanks for your reply
Yes I am very interested ......
Just let me know what to do .......can private messaging be done on this site ?
Paul
Jimarilo
Hi Christian, yes I am still interested
Still new here so can't message you directly
Richie-Van-GTi
Been a while since i messed with an XUD but from memory doesnt the bosch pump normally have a tag with a measured height of the internals which is used to time the pump at TDC? If it does then surely any pulley of correct size and tooth count could be used if it physically fits and be timed that way rather than pegged on place?
Jimarilo
Don't know,  the dial gauge I use for timing my 940 can't get into the hole for the dial gauge, as there is no room and I don't have the adapter
The teeth on the bosch pulley are slightly out compared with the lucas pulley, which still runs ok, but the cold start take a few turns before it goes. The glow pugs are all good
Chris seems to have disappeared
xstian
Hi Paul,
Sorry totally forgot. It was kicking about the house for ages, but now I can't find it. I may have taken it back to work, I'll have a look this week. Sorry for the delay.
Christian.
Jimarilo
No worries Christian, am sure you have plenty of other more important things to think about ;-)
