Gohn
Arm Rests / Doorpulls Broken again
Gohn
if you've owned a 205 you've had a broken one of these
(there's another version on the base model which doesn't look so good as an arm rest but these are the two versions we got here on the Si and GTi)
the one piece rubbery plastic version which has just failed at the usual point
and the other foam filled overmould job that blows out and cracks and automatically s*its itself after a while
this is about the 5th one that's failed and I'm over it
a basic track car door pull was considered, but's no good as mine's a daily regular car
and I use the arm rest
has anyone got any nylon 3D printed versions ? or polycarb, or anything ?
Never broken one of those :huh:
Gohn
that's actually good to hear, gives me a little more confidence in looking for a new set (if they're available)
they were all pretty old
the foam filled ones don't like the summer heat and just deform over here so I went thru 2 or 3 before trying the other kind
and the one I've just broken are german made, both were already used and 25 plus years and maybe the xtra heat here has an effect after a while too
Just noticed  you call it an arm rest, thats probably  why you broke them!   They are only door handles.
DamirGTI
Cracked a few of those during the years .... alu. wire mesh and soldering iron , stitching the broken bit back and it's good to go .
D
Gohn
that's true, might have over-rested my arm once or twice
the base model ones look stronger but there's not as much armrest area
and I kinda figure if I bought it and fixed it, then its there to be used
maybe I'll have to try D, but don't rate my alu/mesh welding skills real high
